Battery for Eclipse?
Home Forums Products Rackmount Battery for Eclipse?
    • #107790
      jcshirke
      Anyone know where to get a replacement battery for the Eclipse? In the US–Radio Shack? Some other specialty store? I assume if I bring the current battery into the store, they'll be able to provide the replacement. Still, just in case, specifics would be appreciated. I didn't find anything in the manual.
      Thanks,
      Jeff
    • #121903
      cyanosaurus
    • #121907
      jcshirke
      Cool…I put in a CR2330 (available at Batteries Plus shops, for those forum members in the US), and I was hoping that would be fine, although I see that Italo said a couple years ago to avoid the CR. I was told that the BR and CR were essentially interchangeable. You can use a CR in place of a BR, but you cannot use a BR in place of a CR–so said the person I spoke with at Batteries Plus.
      It does seem to have solved the internal memory checksum error problem. I had to reset the RAM when I first turned on the Eclipse after installing the new battery. Fingers crossed all is well, but it appears to be.
      Thanks,
      Jeff
