Home › Forums › Products › Stompboxes › Connect H9
Can i connect H9 in this way?
Avalon 737sp (preamp) – Eventide H9 – Crown Xti1000 (stereo final)
Have Eventide H9 correct line input for Avalon 737sp?
Elio from Roma
The Avalon 737 SP looks like it has variable output gain. So, it should work fine. You should be able to use the Avalon's output gain knob to adjust it's output level to get ideal noise performance when used with the H9.
