Home › Forums › Products › Rackmount › eclipse display dead afetr update error
during the process update from 3.0 to 4 with serial cable an error occourred…after power off unit at power on i listen to a click internal but display doesen’t work….
wath can i do????
Try and repeat the update procedure.
If all fails, support@eventide.com
Thanks for reply, the problem is that i cannot see anything on display
The display is totally dead….What can i do?
