My Eventide 4500 has a probelm with the S/P DIF connection. It might be the cables.
I have it patched into my TC electrionics Konnekt 24. using Logic X. The TC software paNEL SHOWS
BLinking signal…it seems there is no S/P DIF connection and there is no sound signal shown on the TC mixer tracks
on the software panel. but there is sound coming through Logic from the keyboard controller to logic virtual instruments,
The LCD screen on Eventide reads as follow under “Set up”
SCMS OUT – Copy free
sample rate 0
S/P DIF Bad
SCMS IN Bad Data
Pre emphasis off
can you tell me please what you can determine from this error message?
Thank you kindly in advance.
