I have an H9 max with Mission SP-H9 expression pedal configured as volume pedal. I recently added one downstream effect (Strymon Cloudburst) and noticed that if I bypass the currently selected effect on the H9 the signal chain output defaults to the volume knob position on my guitar instead of remaining where it was prior to going to bypass. is there any way to have the expression pedal active as a volume control with no active preset engaged? I have tried setting it up before and after the H9 via pedal settings, and would prefer to leave the Cloudburst after the H9 in the signal chain if possible. I am controlling through a Morningstar MC6 if that helps (I am a MIDI noob)
Thanks
