Glitching on harmoniser H9 Max
Home Forums Products Stompboxes Glitching on harmoniser H9 Max
    • #170891
      Bunter
      Hi has anyone else experienced glitching while using the harmoniser? Sometimes it doesn’t quite know which note to pitch to and can make a minor into a major etc.
    • #170897
      joecozzi
      Hello Bunter,
      Can you describe your signal flow? Where in the signal chain are you using the H9 when you’re using a pitch shifting algorithm?
      What are you trying to accomplish when you use a pitch shifting algorithm?
      Similarly, which pitch shifting algorithm are you using to do that? Often times, it’s important to select the right effect for your desired result.
    • #170953
      Bunter
      Hi Joecozzi, thanks for the response.
      The signal flow is  guitar >vol ped> wah> Gigrig G3 – – – then through loops>Tube Screamer1>Tube Screamer2>RAT Pedal> Xotic EP Booster>H9 Max>
      >Strymon Timeline out to AMP.
      I am using it for multi single note guitar leads, much like Brian May.
      The sound I’m using is Quadravox in Pitchfactor.  For most of the time is sounds fantastic but occasionally a harmonised note is ambiguous and off key.
      Thanks for any help!
