H7600 -Mix Tools-Presets use’s
Home Forums Products Rackmount H7600 -Mix Tools-Presets use’s
    • #108571
      scottripple
      I am working with the "Mix Tools" section in the H7600 , Patch #2612"Mixers Toolbox #1":
      can you give me a brief (if possible) description of your targeted intent in a mix setting for this preset? I can learn by trial and error but realize you wrote the program and may can give in depth valuable insight that will take some time for me to discover,  Thanks  Scott
    • #123269
      Unfortunately the man who wrote this moved on to better things and we lack his inside knowledge. Hopefully someone familiar with it will come back to you.
      In the meantime, I had a brief look at the sigfile – it seems to be a collection of useful tools intended to be used to put the "fix in the mix." Essentially eq, pitchshift and reverb.
      The Info page says:
      "Input tone control into pitch shifter, reverb, and delay (chorus). Pitch shifter also feeds the reverb & delay. Final output EQ."
