H8000FW integration with DAW
Home Forums Products Rackmount H8000FW integration with DAW
Viewing 3 reply threads
    • #112651
      dreamatrix
      Hi All, I am new to H8000FW and I am using it integrated with my PC DAW via adat optical. Different projects require different routing, program presets and level settings – let’s call all those settings together a “scene”. Is there a way to recall a whole “scene”? If not what would you suggest as the easiest/fastest way to setup H8000FW with original project in computer?
    • #139495
      Probably what you want is "Storing and Loading Setups" (see UM). This in effect allows you to save and restore the entire state of the H8000.
    • #139504
      dreamatrix
      Thanks for the help.
      Often same favorite programs are used in different projects with minimal adjustment so saving each slightly modified version of the program would clutter the program list.
      It would be great to have an option to save modified programs with setup as well, without having to save them separately first.
      At least to a card if the internal memory isn’t sufficient.
      Would that be possible?
    • #139506
      Anything is possible, but this is a somewhat mature product which we would not change lightly.
