H9 Algorithm Query
Home Forums Products Stompboxes H9 Algorithm Query
    • #115863
      NMillroy
      I used to own a H9 core which over time I converted to a H9 Max by purchasing the required number of algorithms. I believe I reached the number of required algorithms through the H9 Max out program offer. The “My account” section on the settings tab of the H9 Control App indicates I have 12 “purchased” and 1 “coupon” algorithms.
      I reluctantly sold that H9 but now considering purchasing a H9. If I was to purchase a H9 core or H9 standard would my account max it out? I’m guessing it won’t but could someone please clarify?
    • #154575
      bohan
      NMillroy wrote:
      I used to own a H9 core which over time I converted to a H9 Max by purchasing the required number of algorithms. I believe I reached the number of required algorithms through the H9 Max out program offer. The "My account" section on the settings tab of the H9 Control App indicates I have 12 "purchased" and 1 "coupon" algorithms.
      I reluctantly sold that H9 but now considering purchasing a H9. If I was to purchase a H9 core or H9 standard would my account max it out? I'm guessing it won't but could someone please clarify?
      I believe you should be able to use the algorithms you previously purchased, but your H9 core or standard won't be maxed out. You have to purchase required amount of new algorithms again to max out your new H9.
    • #154577
      NMillroy
      I believe you should be able to use the algorithms you previously purchased, but your H9 core or standard won’t be maxed out. You have to purchase required amount of new algorithms again to max out your new H9.
      Will I be able to max out a new H9 core or standard though by purchasing the required number? The line on the Eventide website suggests not?
      The MaxOut option can only be used once – it’s a one time deal. If you MaxOut and subsequently sell your H9 Max, you will not be able to MaxOut another standard H9 or H9 Core.”
    • #154580
      bohan
      "The MaxOut option can only be used once – it's a one time deal. If you MaxOut and subsequently sell your H9 Max, you will not be able to MaxOut another standard H9 or H9 Core."
      I'm afraid you're right. You can still use the algorithms you purchased before but you won't be able to max it out.
    • #154582
      NMillroy
      I’m afraid you’re right. You can still use the algorithms you purchased before but you won’t be able to max it out.
      so the only way I could ever own a H9 Max again is to buy a H9 Max?
    • #154589
      bohan
      Yes. If I were you, I would get an H9 standard. Then you will have 13 (you purchased) + 9 (come with H9 Harmonizer) +1 (a new coupon) algorithms, which should cover most use cases IMO. If you need extra a couple of algorithms, you can still buy them separately.
