This is the second time I’ve had a problem with my H9. First time with a power supply problem cost me $100 to get unti repaired. I’ve spent a lot on algorrithms. I figure I have about $700 plus invested in this thing. Now it will not come on at all. The power supply lights up but even though the power supply lights up the unit does not fire up at all. Do I have to spend another hundred dollars to get this thing fixed? Just about had it with this thing. Any suggestions are greatly appreciated. Thank you
Could you send an email to support@eventide.com about the problem? I can't imagine that if it's the same problem that we'd charge you a second time to fix it if it was a fault in the unit, but the fact that it's happened twice does make one ask whether it's a fault in the unit or whether you might be using the H9 at a venue which provides unstable power.
