H9 questions
Home Forums Products Stompboxes H9 questions
Viewing 4 reply threads
    • #111350
      rosensta
      Greetings!
      Two questions about the H9/H9 Core: I saw something recently that (I think) said that "if you buy an H9, for every Factor/space pedal you have registered, you will receive two free algorithms."  Did I imagine that, or is that a real thing?
      And: can I send MIDI program change & control data to the H9 using only the USB input?  Or do I have to use the MIDI i/o to change programs etc.?
    • #125308
      AAgnello
      One free alg with each h9 purchase. Yes, midi over usb.
    • #125309
      gkellum
      rosensta:
      That is a real thing.  We mentioned it our last newsletter.  That will be available when we release the updates to the Factor pedals that will allow them to work with H9 Control (in March).  After you update the OS of a Factor pedal that allows you to connect it to H9 Control, the app will recognize the pedal and let you use the coupons connected to it to buy algorithms for an H9.
      rosensta:
      Hm. I'll have to double check that and get back to you…
    • #125310
      rosensta
      So those two free Algs (I have two pitchfactors and two space pedals) would be in addition to the free alg you get when you purchase an H9?
      Also: do you also get one free alg with the H9 Core?
      Thanks for the super quick responses; it was great seeing some of you guys at NAMM!
    • #136121
      gkellum
      rosensta:
      Yes.
      rosensta:
      Yes.
      rosensta:
      We had a lot of fun talking to everyone at NAMM as well!
