H90 AND TABLETTE SAMSUNG S8+
Home Forums Products Stompboxes H90 AND TABLETTE SAMSUNG S8+
Viewing 4 reply threads
    • #168573
      SKYDRIVE98
      Hello ,
      first of all I apologize for the mistakes of text, I am French.
      I received my H90 pedal which sounds really good. My concern is that I can’t connect it to my Samsung S8+ tablet. I downloaded the H90 application on the tablet and on my laptop. Everything works fine with my laptop under windows, but on the tablet the application does not want to launch.
      Thank you for your help.
      Thierry BROT
    • #168576
      H90 Control is currently only for macOS and Windows desktop machines. It cannot run on an Android tablet.
    • #169904
      SKYDRIVE98
      Hello ,
      please, someone could help me for the looper function.
      I don’t understand how to get the record, play, dub commands. I don’t know how to choose the time of the loop.
      I don’t know how to choose the time of the loop. Thank you.
      Sorry for my English
    • #169905
      If you’d like control of each transport command, you’ll need to use an aux switch or MIDI controller. If you’d like to control everything from the H90, you can use the 1-button looper. All the information about the looper can be found here: https://cdn.eventideaudio.com/manuals/h90/1.3.0/content/algorithms/looper.html
      Try loading the Looper into Preset A. Then press the Perform button, and press the A LED button until you see the 1-button looper functions. Read the instructions in the user manual above for details about the 1-button looper.  Use the max length parameter to determine how long the loop is.
      Let me know if that clears things up for you.
    • #169919
      SKYDRIVE98
      Hello ,
      thank you for your answer, I will try the 1 button looper. The instructions look complete but my problem is the translation which is sometimes aproximate.
      Thank you very much.
      Thierry
