Hello.
I’m using a delay pedal on insert 3/4.
When I bypass the H90, I lost the delay.
Does the pedal alows for analog dry path when the insert is in parallel? I mean, like path 1 on dual mode. Is that even possible in a future firmware or the hardware doen’t allow?
I’m keeping the H90 engaged all the time in order to have the delay.
The problem is the latency.
I measure 8ms for the H90 with stereo insert.
Thanks.
