Hardware setting to use H9 with DAW interface
Home Forums Products Stompboxes Hardware setting to use H9 with DAW interface
    • #115930
      Armando
      Hello! Are there specific hardware settings when using an H9 as an external FX box within a DAW?
      My DAW interface has both balanced and unbalanced I/O.
      Thanks in advance!
    • #154955
      tsternfeld
      Given that the H9 has unbalanced audio IO, you'd be best served using the unbalanced I/O on your interface.
      You might also benefit from tweaking the levels of your H9 and interface as appropriate, and paying attention to the instrument type setting in your H9.  Depending on the source audio, you can set the algorithm's filters and pitch tracking to a different compromise of speed, accuracy and bandwidth.
