“Kamikaze Drops” on the H9000?
Home Forums Products Rackmount “Kamikaze Drops” on the H9000?
    • #115840
      Ed Driscoll
      Hi Guys,
      Glad to see that everyone at Eventide is staying safe and doing OK working remotely at the moment. I was using my H9000 earlier tonight to try to recreate the pitch drop echo effect that’s called “Son of Kamikaze” on the H3000 Factory plugin version, and a similar effect that I believe is called “Kamikaze Delays” on the hardware H3000. The closest I could get was by fine-tuning the #7614 Magic Echo algorithm. Are there any other algorithms I’m overlooking that can best dial in that sort of effect?
      Thanks,
      Ed
    • #154460
      floresp640
      Ed Driscoll wrote:
      Hi Guys,
      Glad to see that everyone at Eventide is staying safe and doing OK working remotely at the moment. I was using my H9000 earlier tonight to try to recreate the pitch drop echo effect that's called "Son of Kamikaze" on the H3000 Factory plugin version, and a similar effect that I believe is called "Kamikaze Delays" on the hardware H3000. The closest I could get was by fine-tuning the #7614 Magic Echo algorithm. Are there any other algorithms I'm overlooking that can best dial in that sort of effect?
      Thanks,
      Ed
      Hi Ed!
      I was able to get pretty close to this preset using a combination of a few algorithms! I used 3 algorithms in series, Harmodulator, H910/949 and H3000 Micropitch.
      I'll email you the preset and also take screenshots of my FXChain and algorithm parameters and email it to you.
      It's not exatcly like Kamikaze delays, I still have to work on the envelope follower but I think its pretty close. I hope this helps!
    • #154462
      Ed Driscoll
      Hi Patrick,
      Wow, I wasn’t expecting a bespoke patch! It sounds awesome; thanks for putting that together.
    • #154467
      floresp640
      Ed Driscoll wrote:
      Hi Patrick,
      Wow, I wasn't expecting a bespoke patch! It sounds awesome; thanks for putting that together.
      Ofcourse! Im glad you like it!
