MIDI CLOCK PROBLEM
Home Forums Products Stompboxes MIDI CLOCK PROBLEM
    • #170898
      kuryaky
      I need to sync midi clock over usb port, my H9 see’s my TX-6 a midi as receiver and send and I set my, I connect TX-6 as MIDI, TX-6 to send midi clock ( I double check midi its coming send a parameter NOTE control, and the h9 show me that change) but the midi clock don’t coming and don’t sync.
      either h9 don’t send midi clock to TX-6 viceversa.
      maybe a roadmap to solution?
      Either I want to know if the H9 Send and receiver MIDI Clock over BLE.
      please help.
    • #170912
      Have you enabled MIDI clock on the H9? In H9 Control, go to Pedal Settings > MIDI Settings > MIDI Clock to enable MIDI clock receive. You will also need to turn Tempo ON for the preset to subscribe to the MIDI clock tempo.
    • #170926
      kuryaky
      Yes I do! But I don’t know I have to say the preset to MIDI CLOCK I think went it set to GLOBAL it’s just ok, I will double check that one. Thank you.
    • #170973
      No, the H9 can only sync to MIDI clock via DIN or USB connection. Sorry I missed that part from your original post.
