Home › Forums › Products › Stompboxes › New H9 Max Has Problems
August 6, 2016 at 1:39 pm #113621asimmdMember
I bought an H9 Max yesterday Friday and today i have tried using it but there are problems using it with
Bluetooth on my Ipad.
My H9 sometimes wont load a preset then when it does load the preset my guitar signal is dry.
Also after playing with the settings of a preset and moving to a different one there is supposed to be a message
saying the settings have changed would i like to save it I dont always get this message.
The IOS software is up to date the Bluetooth is working and the H9 is paired.
The software has also updated but i still get problems.
The pedal sems to work when used on its own but i want to use the IOS App software to do the editing
because its easier.
Can anyone offer any suggestions please.
I am in the UK.
Thanks
Alan
That's a strange sounding problem. You might want to re-initialize the H9 to its system settings. You do this by turning it off and then turning it on again with the HotKnob switch pressed (the one in the upper left hand corner).
Are you seeing any error messages on the iPad saying a communication error occurred?
August 6, 2016 at 2:29 pm #144053asimmdMember
Thanks gkellum
I already re initialised the H9 but now instead of using it via Bluetooth I have hard wired it via the USB socket
and installed the software on my PC with some success.
I am thinking/hoping it is user error but i am running out of things to try.
I will keep trying.
Alan
If you'd like, you could record a quick video with your phone or whatnot showing the problem(s) you've having. If we could see what's happening, it would be pretty easy to say whether it's user error or not.
August 6, 2016 at 3:11 pm #144055asimmdMember
OK I think i may have sorted it.
When i select say Blackhole and make an alteration to its preset settings it works fine.
Now if i choose a different preset still in Blackhole it asks do i want to save the changes Yes/No.
But if i choose Blackhole and make alterations then instead of choosing another preset in Blackhole i click on
Algorithms to go to a different one Blackhole is still present until i choose an Algorithm and select a preset
thats why i dont get the message asking if i want to save it because i am no longer in Blackhole.
Blackhole is only mentioned for reference it doesnt matter which Algorithm/Preset i use if i do the above
the outcome will always be the same.
Gosh i hope i have explained it clearly enough.
Alan
August 6, 2016 at 4:38 pm #144056asimmdMember
Hi
I have replied but it has not been cleared by the moderator.
Alan
