Orville **help* popup on delays
Home Forums Products Rackmount Orville **help* popup on delays
Viewing 4 reply threads
    • #107629
      violetpow
      Hello Eventide,
      on my Orville i get a new issue, while i'm loading the easy tab delay i get every 2 min a **help** popup on the screen. What does it mean?
      greets
      Mathias
    • #121538
      This means that the unit is (usually temporarily) running out of dsp power. It should not happen in normal use, but may occur on preset loading. If you hear no audio artefacts it can be ignored.
    • #121539
      violetpow
      Hi Nick,
      oh great, i thought its something serious with the Orville. But yes, if it pops up, there is a audio dropout. What can i do against that?
      Thanks Nick!
      greets
      Mathias
    • #121540
      violetpow
      but its happen, not while loading, it happens while i use the effect.
      p.s. sorry for my bad english
    • #132718
      All you can do is to use a lower sample rate where possible, or try other presets.
