I’m trying to set Pitchflex up in H9 control v4.0 and cannot set the MinVAL and maxVAL. Pressing FLEX in h9 control – no result. Ther eis this dialogue in the ‘strip’. I have no expression pedal attached. Setting the General Settings/ Use Expression etc. makes no difference
Anyone understand this?
GOAL: to get H9 to produce a 50c pitch shift up or down.
I see that PitchFlex anyway only allows chromatic (i.e. semi-tone) steps
Anyone know how to do this?
Hi, PitchFlex doesn’t support the ribbon aka HotKonb because the EXP is mapped to the heel and toe position parameters.
If you’d like to use the EXP to morph between +-50 cents, you should use the MicroPitch algorithm and then map the Pitch parameter to the Ribbon/HotKnob/EXP.
