Home › Forums › Products › Stompboxes › please help to get a FAQ straight
May 25, 2018 at 1:54 am #114756PaoloSMNParticipant
I have a registered TimeFactor and am about to buy a H9 core.
I have read the FAQs but need to understand how to connect the TimeFactor to the H9 in order to get the two more free algorithms.
Maybe having both of the pedals in front of me the procedure could be obvious but as I have said, since I only have the TF at the moment I would like to get more info about the connection that must be made.
thanks in advance!
Connect both units (H9 through Bluetooth/USB/MIDI, TimeFactor through USB/MIDI) to H9 Control on your Mac or PC, register them with the same Eventide account. Then you will be able to buy two free algorithms for your H9 in H9 Control.
May 25, 2018 at 6:39 am #149315PaoloSMNParticipant
thanks, now I get it. looking forward to find the h9 available at my shop and take it home (end of next week they say).
I would need to make 2 more questions (hope you will forgive the OT),
1 from the manual it looks like the h910/h949 algorithm does not have modulation but on various preset lists of the same algorithm I have seen choruses and phasers. can you help me solve this mistery?
2 always about the h910/h949: if I haven’t got it wrong, the only difference with the micropitch algorithm is an “eq” control, am I right?
thanks again.
May 25, 2018 at 1:38 pm #149318brockParticipantPaoloSMN wrote:… 1 from the manual it looks like the h910/h949 algorithm does not have modulation but on various preset lists of the same algorithm I have seen choruses and phasers. can you help me solve this mistery? …
I’m not sure about those preset list references, but it’s possible to get “chorus-like” and “phaser-like” (flanger-like) effects. Slightly detuned voices create a ‘beating’ effect with a somewhat similar result, using a different method from slightly offset delay times.
PaoloSMN wrote:… 2 always about the h910/h949: if I haven’t got it wrong, the only difference with the micropitch algorithm is an “eq” control, am I right? …Actually, there’s true modulation rate & depth there, as well. This link might help to explain the differences:
2 always about the h910/h949: if I haven't got it wrong, the only difference with the micropitch algorithm is an "eq" control, am I right?
H910/H949 shifts and delays the pitches, and the pitch module is in the feedback loop so the delays are shifted again and again if feedback goes on. If you set the pitch to some value close to 1.000 (frequency multiplication factor) and set the delay time to really small number (like 20 ms), you will get subtly detuned sound with small delay. With your original dry sound, what will you get? – CHORUS effect.
H910/H949 can shift the note from 2 oct down (freq * 0.250) to 1 oct up (freq * 2.0), while MicroPitch only shifts the sound from -50c to 50c, and it has a modulation module. In a word, it's Micro Pitch focused.
May 29, 2018 at 1:22 pm #149344PaoloSMNParticipant
Thanks again!
June 6, 2018 at 3:21 pm #149430PaoloSMNParticipant
hello, I have plugged both the pedals via usb, I have managed to use the free coupon that comes with the H9 but when I try to use the two coupons from the TF the H9 control gives me this error. how can I fix this? thanks in advance
June 6, 2018 at 3:30 pm #149431PaoloSMNParticipant
ops, think it worked regardless of the error message as I can see the algorithms that I have bought colored, I’ll let you know!
June 6, 2018 at 3:55 pm #149432PaoloSMNParticipant
used the coupons and bought the other algorithms needed. thanks again!
