Hi!
I have an Eventide Time Factor and Pitch Factor, but I need some help with the latter one.
There is some kind of a signal problem with the Pitch Factor – every signal that goes through it is cracking or popping. I’ve tried using my Moog Little Phatty and my guitar, but it’s the same. I’ve also tried changing the source on the Pitch Factor, but it doesn’t fix the problem. I’ve also tried every combination of input/output levels (line, guitar, amp), but it doesn’t help either.
It is definitely not a signal clipping, have checked it over and over again.
And if I use the same input/output settings with my Time Factor, it works perfectly, so I’m assuming that the flaw must be in the Pitch Factor.
I’ve got some sound examples to give You a chance to hear the cracking:
1) Moog through a Time Factor – https://drive.google.com/open?id=0B5Fi_BQr60aTQkdQTkVpVlBHTmM
2) Moog through a Pitch Factor – https://drive.google.com/open?id=0B5Fi_BQr60aTZW5manR6MmVqbTA
3) Guitar through a Pitch Factor – https://drive.google.com/open?id=0B5Fi_BQr60aTc1dxNW9rNUJpU3c
Any ideas what could be wrong???
