Timefactor and Modfactor together
Home Forums Products Stompboxes Timefactor and Modfactor together
    • #107788
      privateland
      Hi
      I'm using OCD –> Modfactor –>Timefactor –> amp.
      Should I select the line level on the out of  the MF and line level in on the TF?
      Either way, levels and noise don't seem to be a problem, but I am curious since it's only recently I've been using both.
      Cheers
      John
    • #121898
      You will probably get the best results if you keep it at guitar level. You really only need line level settings if it overloads on guitar.
