Home › Forums › Products › Stompboxes › Timefactor looper preset help!
Ok, so I searched and searched. I even found an answer on here (well, kinda).
Can the Timefactor looper be saved as a preset? I saw an answer from a eventide mod that said y ou can, but I get the no save on the screen. Help!!
The settings can be saved as a preset in the normal way, but currently the recorded audio cannot be saved.
Ok. I just got it yesterday, can you share exactly how to do that? I keep getting the "no save" on the screen. Thanks!
I'm afraid it is time for some mind-enhancing User Manual reading. It also builds character. And helps you understand the box.
As a clue, the "No Save" message means that you pressed an inappropriate key while in save mode.
Ok, figured it out! This is such an amazing pedal! Another question. Would a software update be possible for the Timefactor to automatically recognize when the device is in looper mode and change to play mode? I think this would be a cool feature.
