Thank you.
A couple of follow-up questions:
1. Does the Out Gain under General control the 8 Output ports?
2. I see that each of the 8 Output have their own mappable level, is this for added flexibility for relative leveles, butmy overall level should only be controlled with a pedal from the General -> Out Gain control?
3. I see that all these volume controls can only go to -24dB and not -Inf dB? Why is that? -24dB would not make rhe volume zero???
