Weird pulsing hum
Home Forums Products Stompboxes Weird pulsing hum
    • #114145
      dustinbox
      Hey, so I have a timefactor and an H9 running in stereo. For some reason now that am I’m playing in some venues that I can have my amps pushed a little louder there is a loud pulsing hum. I have a small boost (tone setting) and comp always on, I turn them off it gets quieter but still there. It continues when I turn off the guitars volume and even when I turn off the volume pedal (it post dry effects pre delay and verb (h9)). The rig is set up in stereo. I don’t always play stereo but I do often enough to leave it wired for stereo. It only stops when I use the complete mute on my boss es-8 midi switcher.
      Any help?
    • #146309
      My guess is that you have some kind of local ground loop, and the "weird pulsing" is an effect operating on the hum.
      If this is the case the solution is at your end.
      See if it occurs with your pedals in relay bypass, and try disconnecting things until it goes away – this may give you some clues.
      • #146310
        dustinbox
        My assumption is a grounding problem. I didn’t think about switching to relay. I’ll try that in the morning and post the results.
    • #146320
      dustinbox
      So that took care of it. Well, the main problem. Now it’s just the expected hum from single coils. Kind of quiet in the background vs it being super loud and pulsing regardless of the gain stages turned on.
      Thanks for the help!!
