I am currently looking into buying a Windows touchscreen tablet for the H9 control app. Would this work on a tablet with a total system memory 1Gb? Also if anyone is using a similar setup, could you share what works well for you?
Not sure what tablet you are looking at with so little memory – the least that Microsoft sells has 4G. Note that a Surface-RT (Arm based) will not run H9Control.
We figure that Windows needs 2-4G as a minimum, so do not recommend your 1G tablet.
