Home › Forums › Products › Stompboxes › What should I do?
July 29, 2018 at 10:57 am #114869malapp10Participant
I have just given a board with 11 Strymon pedals along with a few choice other’s on it. My daughter came to town and left with the board. Funny how that works even when the kid is 28. Here is my question. I have three H9’s, an Xotic EP boost, JHS Muffuletta Fuzz, Keeley C4 compressor and a Lazy J Cruiser Duece (this is one I really love), a Mission volume and a Mission WAH. I have all the gear I need to setup a strong MIDI system. With the number of pedals I have, should I be using MIDI. Most of my gigs are solo in limited space in the Florida Key’s. I use many backing tracks as accompaniments I just have not had an opportunity i to explore MIDI capabilities. Also, if you were me, would you keep the Lazy J Cruiser, it’s always my expirience that people will naturraly gravitate to what they know and I know that pedal well. Thank you in advance for your recommendations and suggestions.
Thanks,
Michael
July 29, 2018 at 10:16 pm #149818brockParticipant
Small world. I’m as far south as you can go on the mainland, and head to The Keys most every weekend. Gilbert’s, to around Hog’s Heaven, or Islamorada Fish Company / Morada Bay area, usually. Occasionally further, like when ‘Irma’ came to town. I also have 3 H9’s on the ‘board, under MIDI control.
You can mine MIDI to great depths, or keep it simple. What are you picturing? Maybe preset control switching only, with all the MIDI-capable devices? External loop switching, over the non-MIDI drive / distortion pedals? Individual parameter control, continuously variable, under an expression pedal sweep? Your answers will help to narrow down the recommendations
There are a ton of options out there now – simple to complex; relatively cheap to expensive. I’d suggest a relatively simple approach to start, and a device with the capabilities to expand as your MIDI knowledge does. And I know what you mean about the venue space, so compact is a priority.
Nice “second” ‘board. But hey, your ‘baby girl’ is always going to be your baby girl. I can’t really speak to your drive / distortion choices, from personal experience. The Keeley has no pedal match. I will say that a good analog or two makes perfect sense in this local market. I drifted away from being a real purist, as digital distortion is getting so much better now (for my purposes).
But with 3 H9’s … you can cover most any sound or configuration that you can dream up. Under MIDI control, the sky is the limit. I run a small rack, big ‘board, stereo amps / FRFR, complex control, and I lug around an FCB-1010 alongside the pedalboard. Not something I’d push on anyone else, but it works for me.
August 7, 2018 at 1:06 am #149880Leo99Member
Hi I own an Eventide Eclipse v4.0 and an H9 Max. Is there a way to load some of the sounds from the H9, which include the ModFactor, TimeFactor, PitchFactor, and Space, onto the Eclipse? Perhaps through MIDI??
