Will Ernie Ball’s MVP work with the H9?
Home Forums Products Stompboxes Will Ernie Ball’s MVP work with the H9?
    • #112187
      Hi all,
      Will Ernie Ball's MVP work well as an expression pedal for the H9?
      Any experience with it?
      Thanks.
    • #139840
      Fenderbender
      *Bump* same question.  I saw that the reccomended impedance for use with the H9 is 10-25, however I cannot find any information on the specs of my MVP Pedal….Can anyone help?
    • #139852
      h9controller
      Hey Rodrigo,
      We haven't tried the Ernie Ball MVP in-house but can recommend the Ernie Ball VP Jr. 25k.  I believe you need to connect the H9 Expression Jack to the OUT Jack of the Ernie Ball VP Jr.:
      http://www.ernieball.com/products/guitar-volume-pedals/2044/vp-jr-25k-for-active-electronics
      The MVP appears to use active electronics internally making it a tad more complicated than the Jr.  Without a schematic or, most importantly, testing the pedal in-house we're unable to say if it's a suitable expression pedal at this time.
