Home › Forums › Products › Stompboxes › Time factor doesnt remember my aux switch assignments…. › Reply To: Time factor doesnt remember my aux switch assignments….
#117163
     In TF 2.0 beta the defaults for the switches has changed – they are set up as FS1,FS2,FS3 respectively.
     These functions drive the alternate mode – e.g. if you are in PLAY mode they will drive the BANK mode switches and vice-versa.
    All you probably need to do is to turn OFF the FS1-3 assignments – they are at the end of the AUX SW setup list.
    These new assigments are causing some confusion, so they will go back to their previous values for the next release.
