Home Forums Products Rackmount Using Eclipse with minimixer to turn it into parallel loop Reply To: Using Eclipse with minimixer to turn it into parallel loop
#117176
Hi Italo,
Thanks for responding. What I was wondering is Eclipse specific. I'd like to use the minimixer to run the Eclipse inside a PARALLEL effects loop. The minimixer has a kill-dry relay so that it can then also run the Eclipse pure series as well. Can I set the effect mixes to be able to run the Eclipse 100% wet, no dry at all, and then on another patch have it be series effect loop friendly? My question has nothing to do with the internal routings. Just regarding interfacing the Eclipse in an effects loop as a series and parallel device with switching. My Gorund Control can control the minimxer's kill-dry. I am only interested in your feedback as to the viability of this concept and/or if you have ever heard of it being done. Thanks!
