Home Forums Products Stompboxes Expression pedal problem Reply To: Expression pedal problem
#117220
joeyray
I had the same problem when using my expression pedal..only going to 88 etc…
I found if I unplug the cable from the expression pedal from the timefactor and re-insert it that it will go the full range…hope this works for you.
