Home Forums Products Stompboxes Can timefactor be adjusted to read in BPM Reply To: Can timefactor be adjusted to read in BPM
#117226
achaput
You can view delay times in Beats Per Minute (BPM) by turning Tempo ON. Tempo is toggled on and off by pressing the Encoder button once.
When Tempo is ON, DLY Time A and DLY Time B are set in rhythmic sub-divisions of the beat, i.e. note values from 0 delay to a whole note in common note increments rather than milliseconds. The value of the BPM is tapped in via the Tap footswitch. You can also manually dial in an exact BPM value by tapping the Tap footswitch once and then turning the Encoder knob.
Alan
