Home › Forums › Products › Rackmount › H8000FW – What’s your Sample Rate? › Reply To: H8000FW – What’s your Sample Rate?
April 3, 2008 at 8:51 am
#117304
IDeangelis
Calvin
you may also try a CLEAR SETUP (check the manual for Start-Up options) in case many tests and external/internal clock switching have been frequently done.
You could also try the MVRacks presets, in the same bank. They offer the same fx and more programming options.
best
I
