Home Forums Products Rackmount Presets Reply To: Presets
#117469
IDeangelis
Hi
unfortunately there is no other way to get presets at the moment.
The best you can do is to sit down and reprogram Eclipse for your needs. When copying parameters values from a machine to another you should consider another even more important aspect: algorithm structure.
If your old unit has some diagrams of the FX structure, you could compare it to the structures available in Eclipse; check the Presets manual for diagrams of all algorithms. Choose the one that more closely resemble your old midiverb. Then copying parameters values may help.
all the best
