Home › Forums › Products › Stompboxes › Is anyone using an expression pedal? › Reply To: Is anyone using an expression pedal?
May 11, 2008 at 12:29 pm
#117480
ljholland
Actually, rather than using the bypass switches to turn effects on and off, I have the expression pedal set to change the mix from zero up (in addition to other settings as well). Then, I can blend in delays appropriately for the situation. Lately, I've only been using a couple of presets instead of a bunch where I had created delays with different "intensity". The other advantage is that it's another "on/off" switch using in this manner.
