Home › Forums › Products › Stompboxes › Post your TimeFactor V2.0 Beta bugs here › Reply To: Post your TimeFactor V2.0 Beta bugs here
May 31, 2008 at 11:54 pm
#117525
Im not getting a seamless bypass when the pedal is set to dsp/spillover. There is a very noticeable drop in sound when you hit the bypass. The delays still trail off but the dry signal is cut very briefly.
edit *Its noticeable when turning the effect on. You should be able to easily hear it by turning the repeat knob to off, struming a chord, and turning the pedal on while the chord is ringing out.
Also on the tape setting goes into oscillation at around 64% feedback if the delay time is short. Depending on the wow and flutter in can start to rumble and wave very loudly.
