Home › Forums › Products › Rackmount › Eclipse V3.5 Block bypass externals – problems › Reply To: Eclipse V3.5 Block bypass externals – problems
June 16, 2008 at 9:16 am
#117592
Mr_Clean
Hi, Ok setup the Ground Control to cc 65 & 66. Works inconstantly (but better than before) ! Sometime appears to be in sync other times not. Not sure but I think maybe going from a single FX block preset (band taps) to a dual in series preset (Diamond Rain), it looses the correct bypass status. what do you think ? cheers Mike
