Home Forums Products Stompboxes Mix level question on Timefactor Reply To: Mix level question on Timefactor
#117641
I think it would be a nice feature if this was modified somewhat –
So the dry signal would stay the same level, and the wet signal could reach 60-70%.
For example, instead of a 40% dry 60% wet, it would remain 50% dry and 60% wet, essentially leaving the dry signal intact longer.  This is how the Line  DL4's mix works.
