Home › Forums › Products › Rackmount › Eve/Net rotary encoder resolution? › Reply To: Eve/Net rotary encoder resolution?
July 7, 2008 at 3:31 pm
#117643
The resolution of the rotary encoders varies depending on the parameter being controlled – one click on the encoder will be the same as one press on the up or down arrows with the same parameter selected.
The resolution of any parameter can be changed with either Vsig or the built-in patch editor, but they are usually set to reasonable values.
The Eve/Net response time is pretty good, but will not be faster than the controlled unit itself, for obvious reasons.
