Home › Forums › Products › Rackmount › Error message when “copying” › Reply To: Error message when “copying”
#117856
Ok, that works. However, when I copy a preset to anywhere in the 1-99 range, my midi controller cannot find it. Here's what I mean:
I have my midi controller set up on the same channel as my Eclipse. The midi controller is able to access the Eclipse and make changes. However, if I tell my midi controller to access Preset #1, it goes to Preset # 101. I'd be happy to work around this by saving the #274 Preset to #101, but the Eclipse will not let me. It will only allow me to SAVE a Preset to # 1- 99.
The COPY function allows you to COPY a preset to ANY preset number, but as you know this does not work with multi-algorithm Presets.
What can I do to gain access (via midi) to Presets 1-99?
Thank you,
Joel
