Home › Forums › Products › Rackmount › Eclipse DDL dulls original guitar signal? Audio degradation. › Reply To: Eclipse DDL dulls original guitar signal? Audio degradation.
November 11, 2008 at 10:00 am
#118007
simeon
might be a good idea to set the mix parameters in the Levels menu (not in the Main section…in the Parameters section) to about 35% and set the send value in the delay block to 100. this will let some dry signal through so you'll retain your high end
