Home › Forums › Products › Stompboxes › good midi pedal controller for timefactor (and later pitchfactor) › Reply To: good midi pedal controller for timefactor (and later pitchfactor)
sathy.ngouane:
I currently use a Ernie Ball Mono Volume pedal ( 6166 ) as an expression pedal to control my TF. And as Aux Switch, the small Digitech FS3.
Hi sathy.ngouane,
thanks for your reply.
Yeah I know about the ernie ball and the FS3 but that will take two cables running from the peadlboard to the TF at my amp. I asume you haveyour TF on your amp instead of your pedalboard?
via midi that would be one cable therefore my question.
Maybe I'm making a big deal out of nothing.
Do you use the FS3 to change patches? If so what do you do to tap tempo?
(or go a bank down instead of only going up)
Thanks again.
Jesse
