Home Forums Products Stompboxes Time Factor Global Setting Reply To: Time Factor Global Setting
#118456
achaput
It's nonfiction!
Global affects the way Presets load. If you set Global Mix to ON then every Preset's saved Mix setting will be ignored and the Mix value will always be set to wherever the actual Mix knob is pointing.
If you set Global Tempo to ON then every Preset saved with Tempo On will load with the currently tapped-in tempo instead of the tempo saved in the preset.
