Home Forums Products Rackmount Eclipse settings – Midi pedal program changes… Reply To: Eclipse settings – Midi pedal program changes…
#118543
IDeangelis
 Hi Balazs
Eclipse uses 3 different MIDI Maps to patch program changes to presets.
MIDI Maps can be choosen (and programmed) under SETUP > MAPS.
Eclipse presets are divided as follows:
0>99 user memory
100>499 factory algorithms and presets
500> 999 user memory on Compact Flash Card ONLY!
The 3 maps work as follows:
Map 1 Program change numbers 1-100 select factory programs 100-199
Map 2 Program change numbers 1-100 select user programs 0-99
Map 3 Program change numbers 1-100 select card programs 500-599
Is this helping you?
best
I
