Home Forums Products Rackmount DSP 4000 connections Reply To: DSP 4000 connections
#118559
IDeangelis
 Hi Sylvain
we have never tested the unit with both +4dB and -10dB I/Os connected at the same time.
You will have to try IF this works, when you switch from one format to the other.
If it doesn't, you may need to make a choice.
all the best
I
