Home › Forums › Products › Stompboxes › midi amp with eventides › Reply To: midi amp with eventides
May 11, 2009 at 1:41 pm
#118594
shane-eventide
sure
just plug a midi cable from the flextone midi out to the factor's midi in
I think the default settings will work except one
turn on program change receive in the factor's utility settings
then when you change presets on the flextone the factor will change too
