Home › Forums › Products › Rackmount › Floating 5ths to H7600 › Reply To: Floating 5ths to H7600
#118752
C6
    Thank you for the message, I. Here is what I recorded from the GSP:
    Compressor: on, ratio: 1.5:1, thresh: -30 db, level: -6 dB
    Distortion: bypass (I think I shut it off, I can look this up if you need it)
    Analog EQ: 7 Band, 80 Hz: 10 dB, 160 Hz: 4 dB, 320-640-1.28K-2.56: 0, 5.12K: 6 dB
    Master Vol: 1 dB
    Ext FX Loop: loop: No Sum
    Stereo Noise Gate: on, thresh: -64 dB, Hyster: 6dB, Holdtime: 20 ms, attack: 0 ms, release: 50 ms, attn: 20 dB, delay 5.0 msec
    Pitch Shifter: on, level: 45, predelay: 0 ms, pitch: 7 tones, detune: 0, track 6-10, regen: off
    into 2X1 Mixer, lev1: 100, lev2: 100, outlev: 100
    4 Phase Chorus: on, level: 100, delay1: 10.00 ms, delay2: 20.00 ms, delay3: 30.00 ms, delay4: 40.00 ms, speed: .34 HZ, depth: 5.5 ms
    into 5X2 Mixer, input1 lev:100 pan: -50 (L), input 2 lev: 100 pan 50 (R), input3 lev: 100 pan -23, input4 lev: 100 pan 23, input5 lev: 100 pan: 0, output left: 100 right: 100
    Mono delay 2.0 sec: on, delay: .375, fbk: 20%, level 60, rpthold: off.
    On the sour effect thing, I will look into that.  It may be something I am doing, but it seems that pitch shifts combined with delays give me this effect.  The do not repeat true to their first pitch shift.  If I change the track 6-10 on the GSP, I get a similar effect.
    C6
