Home Forums Products Rackmount H8000FW problem: DSP code 2001 Reply To: H8000FW problem: DSP code 2001
#119179
    This error indicates a possible DSP hardware problem. At powerup, the unit resets the DSPs and then waits for them to assume the correct state – if they do not in the time allowed, it reports this error.
    If it only happens occasionally you may wish to ignore it, but otherwise the unit will need to be serviced. If the unit powers up without error it will probably then run OK without audio issues, but we cannot say for certain.
