Home Forums Products Stompboxes Can I use TimeFactor in my Series Effect Loop? Reply To: Can I use TimeFactor in my Series Effect Loop?
#119685
alwalt
Hi Trazan. I own an DC30 clone by Ceriatone. I'm using the TF on the effects loop, and my repetitions are distorted even when the overdrive indicator light its no lit. I've been forced to turn my mix control to 5 or 6 (of 100) to avoid this. It happens to me even when I use the amp on a clean setting.
It also happens when I use the Timefactor on the effects loop of my JSX Minicolossal.
When I move the "in – out" line/amp switches, overall volume change, but the distorted sounds keep going.
Any hint? Am I missing something?
