Home › Forums › Products › Rackmount › A-Dial responsiveness › Reply To: A-Dial responsiveness
December 29, 2009 at 3:21 pm
#119691
Not quite sure what you mean by the A-Dial – is this the big knob ?
The resolution of this knob is programmed into the places where it is used – changing a preset is a bigger thing than tweaking a parameter so it takes more effort.
There is a knob speed setting under SETUP – make sure this is set high enough.
